Aslam O Alikum Guys
I bought Cultus 07 as my first ride in November last year with next to none past knowledge of vehicles. Bought Rear Xplod 6x9 and got them installed by electrician.
but inspired by agoodfriend's cultus thread and motivated by my dearest friends @nasirjaved @saboor73 @nfsmostwanted @peace-maker @dragonheart786 and others, I have started doing these little works myself. Now to the topic
Cultus comes with ff wiring but mine didnt have any. So I'll be doing wiring as well
Stuff Required :
1. Speakers 4inch
2. Wire 3meter
3. Electrical tape
4. Screws and Screw Drivers
5. Scissor and wire cutter
6. Patience and Courage
7. Suzuki Cultus
All stuff Together
Speakers mounts where speakers are to be installed
Left
Right
Both Sides are almost similar so I will show only Left side
Take off this Plastic Pin
Unscrew these screws
Takeout the mounting cover
Finally this mount will appear
Route the wire in this manner
Peel off the plastic from wire
Finally connect it with speakers (positive and negative terminals must be considered]
Put the cover back and we are done here
For connection with Head Unit, take out these lever buttons by pulling with bare hand
Unscrew these
Pull out the grill and take out head unit
Locate the front channel wiring
Reconnect with new wiring from right and left channel
Do reverse to assemble it
Enjoy
Disclaimer : I am not professional and my work can have many flaws. I am not responsible if your cut your finger. Set your audio setup on fire or anything
Applicable to Margalla as well
Regards
