remove the front indicator check for the green wire it must be cracked / broken at the plug terminal. a very common trait of cultus.
test lamp simple - buy a simple tester remove the neon from it add car roof light cylindrical bulb add an extension wire to the ground clip and it is ready. wire goes to ground and the TIP is to locate positive point & leaks.
Rs. 100 for a locally made like this
