3: It's definitely something wrong with AC Cultus AC is good enough to keep the front passenger's cool.
4: It's absolutely all right cultus does 120km/h at 3.8-4k rpm no need to worry about that.
6: Keeping in view you got it used so get all the fluids checked and as it's a efi engine use some good 10w40 or 15w40 oil grade with maximum api rating of SG, SJ.
Get its gear oil changed pour in ZIC gear FF 75w85 approx 2.5 liter is the capacity i think.
Check the condition of brake oil and change or level it if required. Also get the brake pads inspected.
Check for the condition of all the rubber hoses fuel/cooling system and change the required hoses.
Pour in some good quality coolant.
You are good to go...
Sent from my D2502 using PW Forums mobile app
