i have cultus 2007 non my cultus oil reducung 1.5 litr in 2500km there is little bit blue smoke when i start car after some time it dissapear so whats the matter
Check PCV valve if its dirty it will suck up oil instead of Vapours.Its cheap to replace though.Other reasons include Worn out Piston rings or leaking Valve oil seals.Blue smoke indicates that Oil is being burnt.
little bit blue smoke when i start it means there's problm with rings and piston
Ring plus piston.. also glass will be change
Glass?
kitna kharcha a jay ga total?
piston Glass...in.which piston.is moving..so engine will become standard.
Itx efi or cdi engine??
You mean the cylinders/liners?
cdi
