Thank you soooo much Bro Usman_aroog2 & atifnaeemmalik... Yes I opened radiator cap and not the bottle cap. I took full precaution and used a big cloth to cover the rad cap and opened slowly. However after waiting for 10-15 minutes with engine off there was pressure and after almost 20 minutes it was gone so I topped up with water and went on.
So its no big deal and I should not worry...right?
But another thing is that its not sucking water from the bottle and water gets reduced from radiator and bottle level remains same. I will check the pipe from bottle to radiator. Should I also try air bleeding the system?
any suggestions regarding making it auto? and also temp gauge remains at 10-20% ... how can I check where it is connected to temp sending using on engine? I will also try stopping rad fan to see if needle rises up to middle point or not..
My brother also suggested to get radiator serviced to make sure its all well so please suggest any good one in Lahore.
thanks again mates for your valuable feedback
