Salam Pakwheelers!
I need your help once again. I own a cultus and currently its in stock condition Audio wise. I have the original rear fiberboard/phatta with stock speakers. It is without CNG (cylinder removed) and since the car is currently being used as a family car so the TRUNK space is necessary. I want to keep the trunk space yet want to upgrade the speakers. so kindly give me any idea for this.
Well I have this idea in my mind, make a shallow cube enclosure, add 4 Circular 3-Way (low, mid, high) 6" speakers on it. The cube depth should be shallow so i can put it in such a way that it remains moveable just like the original fiberboard.
So in this situation can you suggest me any good circular speakers , 3-way shallow ones will be a preference. I need punchy base and good mids. Should i use 2-Way speakers and install tweeters along or just a good 3way pairs would be enough?
Extras: also tell me should i use 0.5" Lasani? or you recommend 0.75" MDF for construction of cube. which would be lighter yet durable.
Can these speakers need to be operated with AMP or just with 50wx4 HU Pre.
More important budget is around 15k
something like
or something like this kinda messy.
