PLEASE HELP!!!
i have a suzuki cultus 2008 efi, more than 2lakh driven, did the following work but the rpm is fluctuating from 1000 to 2000 and back and car is missing a lot and also misfiring sometimes, car turns off while driving, in neutral on speed breakers. kindly please help and if possible also recommend good speclist in lahore.
work already done:
1- engine seals/ gasket replacement
2- genuine spark plugs
3- throttle body replaced
4- tramission overhauled (gear oil seals)
5- suspension also overhauled
6- engine tuning/ oil change oil filter/ air filter/ gearl oil brake oil changed
7- radiator changed to lords copper with coolant.
kindly help what could be the issue of unstable rpm, could id be electric issue?? and if It resolves then my next step is to work on ac/heater , kindly also recommend ac mechanic in lahore.
thanks brothers
