Salam everyone! I have cultus 06 carby and i want to ask that after how much km should i change my spark plugs!
Also bit confuse in checking km there are two parts of number rolling in speedometer ,which one is for km can any one tell me
both are n km but above is original total mileage not changeable... below have a pin to do it zero for different purpose like fuel average, distance calculation, oil reading...
after 20,000 km change the spark plug... do oil change filters change and with it spark plug change at same time
Thanks alot abdul wasay!
I have changed spark plug in my cultus10 from standard NGK to Denso Iridium Power, now pick & acceleration improved drive like hunda cars. So suggest u to use origional high quality spark plug & feel the result..
Sent from my XT1254 using PW Forums mobile app
If ngk change at 5000 and of iridium change at 10000
iridiums can easily last upto a 100,000 kms.copper ones can last upto 25000 kms
I usually buy NGK.
Better to buy geniun denso w20 result much brttr than NGK.
ngk is brand and iridium is a metal.dont confuse yourself and others between them.
I don't.
please mention the part or item number for carby cultus 2004..which code is required for buying denso or ngk?
