i got cultys model 8...steering was soft and smooth having bigger sized tyres then oem...but few days ago my frend got my car for some trip..after that the steering is hard..i dnt know what he did with it..anyone help me to solve this>>>thanx
Check tires pressures...do ask your friend what he did, if rest of ur car is fine;)
Bigger tyre always create problems..its not your friends fault (may be )
check tyre pressure,
may be he drove the car rougly on unpaved road, get its wheels balanced and aligned.
got air pressure checked..now better ...but not fully set...he just drive on motorway as he told me..
anything to assist in driving ?means steering *** is gud or bad?
steering ***
Ur tyres and rim is not matching ur car specs dear better to have OEM tyres or if u wana change then keep to same size or tyres and rim u can read article about tyres and rims here in forum
You have EPS or oil based power steering?Check whether power steering oil is leaking or below the specified level
if its VXLi then check the power steering fluid,if VXRi then check tire pressure and alignment or camber may be needing adjustment
