i have cultus 2007 carby... i have changed my new tire DUNLOP TOURING TI 2 months ago... I run almost 2000 km after that... the main issue is my CAR VIBRATES AT 70KMH EXACTLY NOT ABOVE OR NOR BELOW 70KMH... I BALANCED THE WHEEL 1 WEEK AGO AND ALIGNMENT TOO... ALIGNMENT GUY SAY TIRE ARE GOOD NO TIRE IS SWELL... 50% VIBRATION IS LESS BUT STILL I FEEL VIBRATION ON CARPETED ROAD... PLZ HELP
i would say its some sort of suspension issue brother
same issue with my khyber , I installed dunlop sp touring one month ago , at spees 80 it vibrates alot
Its a problem of wheel balancing visit chaudhary motor work shop national market rwp near chandni chowk @ ch motor they will resolve ur issue inshallah
You should align your car and wheel balance from rwp ch motor near chandni chowk
Get wheel balancing done that too from an experienced person
One of my friend has a 2007 cultus and had the same problem. It was vibrating a lot and he got it fixed by balancing wheels and alignment. Get it done asap because it is dangerous to drive in such condition.
Vibration is Wheel balancing issu .....
same prob with my cultus 2004, Small Chimta bush to be replaced.
do u mean ball joint???
get your car's tyres and rims checked, wheel balancing and go for some sort of good tyres like yoko or bridgestone. Hope your problem gets solved
Get wheels aligned and make sure if your alloys/rims arent damaged, as they bend slightly
Sent from my SM-G900F using PW Forums mobile app
Super wheel alignment double road choke near zawaj shadi hall rawalpindi.
