Keya VXR ya normal cutlus k steering ko Powersteering may convert keya jasakta hay ? or keya ye aftermarket changes tung to ni karti ya koe reliable solution hota hay ?Secondly may aaj kal car search kar raha ho cultus to market may 2012 k baad sab models VXR he arahay hay or powersteering jin may hay wo sab after market hayn. Keya suzuki nay cultus may powersteering 2010 models k baad add ni keay kisi variant may ?Sab showrooms walay bhi VXR he dikha rahay ya VXR ni hay to bhi power steering or power windows etc ni. wo kehtay k 2010 k baad kuch years tak powersteering ni aya. Keya ye such hay ?
You can get EPS (Electronic power steering) installed in Cultus.Around 9 to 10k expense. I did the same.
vxl and vxli variant had HPS factory fitted, worked pretty good
From where in Rs.9,000 to 10,000? In Karachi, they quote 18,000 to 20,000.
After market EPS works fine if you have a reliable technician. You will find Japanese Cars parts that should fit in Cultus with no modification.
I was talking about Rawalpindi. Got it done for someone last month for 9.5k. I dun kno why its so expensive in khi with such big market.
@Vaqas1 in which cultus model you have done?
@xenerking bhai aapnay kaha say karwaya hay or kis cultus model may keya hay ? cost keya ay hay ?
@Vaqas1 please rawalpindi jis shop say installations karwy hay uski location bataden.
i just mentioned which cultus varients had factory fitted PS, u can find same in junkyard n convert ur car
I got it done in my 2016 Cultus, in Karachi for PKR 16k two months ago. As stated earlier, others were quoting 18k to 20k.
In 2001 and 2004 Cultus. Danish Chah Sultan Rwp. 0332 9944877
sir muje yeh batain k yeh speed sensor k sath hota hai? jese youtube py videos hain k speed sensor kit k sath
I am also interested in getting EPS for cultus 2007. Have you experienced any issues with it so far?
One issue. The cross he used became a bit hard. Replaed that with a good one. Otherthan that its working great, Steering is very light.
