You can clean the throttle body, use the Liquimoly fuel system cleaner, inspect the Fuel Pressure regulator this is the main culprit for most petrol cars having low mileage as I myself faced this issue. Check if the vacuum side of the FPR is having petrol in it by removing the little vacuum pipe connected to cylinder number 3 on the engine. If there is petrol or you can see it wet then the FPR is bad and leaking petrol directly into the intake plenum. Then obviously the ignition system need to be checked, plugs, wires coil and distributor Cap and rotor, replace any component that seem worn or damaged. DO NOT HAVE THE INJECTORS OPENED! unless by a very good and professional mechanic as they mostly leak after refitting instead use the Liquimoly fuel system treatment first. Also try using the Liqui moly MoS2 oil additive on next oil change.
