before swap
before rims
yup everything , more or less 60k.....make it more then 60k
auto trans, gear lever and brake paddle
new rims tyres
auto trans rpm speed o meter
engine , 860cc efi
cng rempved
It was looking good too even before swap.Mashallah beautiful car,looks in good condition.Engine swap isn't easy decision but it sounds good your car is like new after spending 60K, on other hand I have spent around 40-50K on my car & still there are major works remaining to do like engine seals,gear box work,tyre changing & much more.so far I have done AC,head gasket changed,both wheels hubs changed,lights covers changed,radiator serviced,brake servo changed twice as replaced kabli just worked for 1 month
Sent from my Z10 using PW Forums mobile app
Tyres are brand new or kabli?which company & size?price of tyres?
Is RPM meter working properly accurately?
experience makes it different, at least after some time you will be an experienced guy...spending alot of money but getting more worst, i can understand your feelings sir...
cuore parts are expensive and difficult to find...
13 size of rims, cuore original rims, bridgestone tyres kabuli tyres, 19k for set and 600 for rims nuts , 19600, for fitting , allignment, balancing...got it from pindi
ithink i mentioned 17k, its not 17, got it for 19k
obviously its working perfect...
every changed item is working perfect...
You changed side mirrors too?Tyres,rims are cheaper in peshawar then pindi?Did you sell your cng kit,cylinder or get adjusted price when exchanging engine?
The work should be done like the brother above did....bro dont get the engine overhauled just get an efi engine in ur car for piece of mind as evrry issue will go away itself...efi cars are easy to work on now...and older engines wont be in good condition you should not go for overhaul and change engine with efi one...even if you are not experienced its not an issue settle a rate with everyone and pay after you are satisfied...abd the work done aboce is the perfect amount to get the work done as everything in car gets new....if you spend around 75k on the car it will be as good as new
Sent from my GT-I9500 using PW Forums mobile app
