Cuore 2002 model clutch cable bar bar toot rahi kia waja ho sakti hy koi hal bata sakta hy
clutch fork is sticky & the thrust bearing must be faultywhen was the last time clutch kit (clutch plate pressure plate thrust bearing) was changed ? remember manual transmission also require oil change. as well @pwuser171353395332 @dani_kk @syncview @rajaatta @Xulfiqar
Check if the cable is bent while installing. If you change just the cable, and not the cover, it might break due to dryness inside the sleeve.
Check your groundMostly poor ground causes to catch ground from clutch cable and this makes the metal wire to get hot and damage the cable and after some days it breaks again.
