Hi Dear Fellows....my cuore's (cx eco 2010/11 driven 65000km) clutch plates getting weak Day by Day...now i want to replace them...kindly suggest me the best plus economical brand(یعنی چوپڑیاں اور دو دو )and where should i buy...Do suggest me a good mechanic too if u know him personally...JAZAK ALLAH kHAIR!!
buy AISIN clutch kit from open market. if you are in lahore goto Obama car care tipu block garden town 0321 4106898 - in Karachi call upon Jameel Autos 0300 223 7538
thanx bro.
Keep in mind that when you are going to work on the clutch the whole engine is going to be taken out as thats the only way to replace the clutch plate in Cuore. You will be able to check the engine mounts as well and replace if they are broken. Go for the Korean make which will probably cost around 7k and labor should be around 4k. Good luck!
thank u sir for your valuable tips...replaced the clutch n pressure plates yesterday, got Aisin brand in Rs. 5200, bearing 800, timing belt 450, gear oil 2ltr 800 and labor Rs. 2800...mountings were ok..Jazak Allah
