How can you trust a car with a corroded cooling system to get you from point A to point B successfully?
God forbid, someone is after you. If youre smart you will gun your car.it heats up and the rust holding the system lets go. The coolant (or water) leaks out and you have an over heated car. Either the goons get you or you reach a safe spot and you have a seized engine.
My point is, water reduction should be zero. Get it repaired ASAP.
Sent from my GT-I9500 using PW Forums mobile app
