few days ago i installed JDM speed o meter in my cuore. its RPM goes one point up and then back when right indicator is turned on. for example when engine is on, if needle is at 2, with right turn indicator on, it goes to 3 and comes back with indicator turning on and off. it has three terminals. 1- battery positive 2- ground that is shared with right turn signal. 3- rpm signal from ignition wire.
rpm works fine when hazard signal is on or door is open. this only occurs with right turn signal.
so what can be the problem. what to check?
