I got civic 04 eagle eye exi prosmatic
Civic exi is converted in exi promsatic. If we run in N (neutral) either for 3 hours no issue but when we put in D (drive) after some kilometers car will stall and it will not start again. After few minutes and some long selfs the car start again and will do the same but this time the kilometer it will drive is less than before
Main Problem Cause
after I boought and do the 1st oil change. It is the 1st time I faced the problem
Procedure
mechanic changed 1 plug
2nd mechanic told me to change the coil and all the plugs
3rd mechanic told me to change the fuel pump and service the fuel filters and fuel lines
I also deactivated the central locking system if it is faulty
Please guide me
