Oh man!!
If you hear the local lingo of these motorcycle mechanics in Khi, you will want to plug your ears, apparently honda cg125 has a unique musical engine sound.
Facepalm!!
Forgetting its an aircooled agricultural level aluminium alloy, noisy as hell engine. These same mechanics also do moronic acts like installing the piston with minimal clearance (pishtamm khud jaga banadega as if an aluminium piston can machine an iron bore) balance a crankwheel with hammers, seal engine with garbage level sealants etc.
