its not a myth , its a proven reality,,,,,,,,,,once i have done that mod on mehran 91 followed by another mod done in carb to activate its second butterfly,,,,,,,,,,,,,car can fly up to 140 very very easily on AC/CNG,,,,,,,i belive if that same mod done in newer model of mehran with perfect body and suspension than it can easily cross 160,,,,,,,,,,,
its a very very painstaking job and need lot of patients ,,,,,,,i remember i spend almost 10 days on porting,,,,,,,,,,,,,you can see lot of junk metal which company wont care to cut off after casting ,,,,,,,,,,inside intake and exhaust port,,,,,,,,,also along with the valve seats,,,,,,,,,,,,,clean all of that ,,,,,,,,bore it by grinding off,,,,,,,,,,,also focus on trimming the head face to improve the compression ration,,,,,,,,you need burette to measure the compression ration,,,,,,,,
all that is not as easy as it sounds,,,,,,,,,,
i use this tool attached in pic,,,,,,,,,,
ImageShack® - Online Photo and Video Hosting
