For checking the compression the engine must be fully warmed up (recommended).then turn off the engine and remove all spark plugs from engine.connect tester to 1st cylinder and tell ur friend or somebody else to crank the car for at least 10-15 rev.read the maximum pressure on gauge and then press the safety release valve on gauge to release the high pressure before removing.repeat the same process for remaining cylinders.
