where are you located?
Like I said, 3 stage engine is a very good engine as confirmed by users all over the world. However, it is only good when properly swapped and wired.
My wiring was done by someone who knew what he was doing, and started the car, but he hadnt experienced this engine before. It was my fault not to use any known wiring guy.
Thats why i said you will need the best wiring guy so that everything is done perfectly do get all components of the car working. My speedo doesnt work and therefore vtecs dont engage. There is work still required in my car but unfortunately due to time constraints I havent been able to sort things out.
All you need is a good swap and wiring guy, and you are good to go with the 3 stage. If you find a wiring guy like mine who will just get your car started and running, then you will face complications. If you have doubts, then just go for a simpler swap.
Just an update to my previous mileage figures, I filled up Rs. 1000 petrol (12.9 Litres) when the fuel needle started touching the End line, and now after 115km, the needle is very close to the End line. As informed earlier my speedo isnt working so cannot know the actual KMs, but using Google maps, I kept track of all my running and this has totalled to 115km. This means I am getting a fuel average of 8.9km/Litre. This is not bad at all considering my car isnt properly tuned.
