Dear All, and (testDrive)
I am happy to see that now really understand GM EFI.
Could someone help me in replacement of Daewoo Racer A/C with conventional A/C used in Toyota/Honda/Suzuki etc ..... . The problem I have faced is with high/low pressure switches and ECU signaling while A/C Clutch ON.
I tried to connect conventional a/c, when it turn ON, idle speed drops or engine stop. However, A/C was working and satisfactory cooling achived.
I feel, it can be possible to connect a conventional A/C in daewoo Racer if wiring is handle properly. or 12+ will be provided to ECU desired pin.
Need valuable feed back from all and specially testdrive.
Regards,
Abdul Rauf.
