@akifjanjua & @test driver
I bought the bumpers from FEDERAL AUTOS I-10 4443594,4440508
They are original daewoo racer 1994 GSI bumpers.I bought it for Rs.14000/- with adjusting my bumpers.Local market ones are all almost damaged or worn out but these were arranged via Karachi.They still beared its original navy blue colour on which this colour is sprayed.There were no dents just needed mild adjustment which they did.Best feature about them is that they dont scrap paint off with minor hits but scraps off as other plastic bumper vehicle colour does i.e forceful hits.
@undisclosed
Get a branded geniune rotor not the replacements.Get the sensor located in the distributor checked.Clean all engine and body ground wires and rescrew them.Check plug wire between coil & distributor(centre one).Get your distributor pick up coil checked.If distributor not serviced since 70000km then get the whole distributor parts e.g pickup coil,rotor,distributor cap etc replaced.
As for the tick tick sound,as test driver quoted,check that the oil light goes out just as you start the vehicle.Change oil type to Caltex Havoline formula having blue cap(3000km life) or red one(5000km life).Change oil filter to genuine one as it has better material then conventional ones and is designed for this engine thus provides optimum oil flow.The sound stays for 3-5 sec but reduces after 10 sec to almost nil---Normal Also keep in mind that the temp during the night is -1 to -4 thus water becomes frozen and can cause hindrence to oil flow(Oil viscosity increases with lowering of temp i.e becomes thick thus flow speed reduces).Frozen Water returns to liquid state first and then starts getting warmer causing initial heat generated by engine combustion chamber to be initially used to liquify frozen water leading to elongating the process of engine to reach optimal temperature. .(To avoid this situation replace conventional water with good quality imported coolant).
As for BRAKE PROBLEM, Cheaper better solution is to change both drum leathers and disc pads to Geniune ones.Check if disc rotors are al right if not dont line them just change to genuine disc rotors worth Rs.2400/-. Service and lubricate brake calipers.Replace brake cylinder seal if movement of cylinder restricted.Avoid hard braking for first 200km and always use lowest gear while coming downhill with providing a rest of 10 -15 sec between braking.NEVER FLUSH WHEELS WITH WATER IF BRAKES BECOME HOT AS THIS CAUSES DISC LINIG ERROR AND DISC PAD BREAKAGE(MATERIAL). I have done this and am enjoying excellent braking
I have also installed DENSO IRIDIUM 3 point Plugs in my daewoo.Missing reduced to almost nil and cold state acceleration has increased by 70% with mileage improvement upto 13km/l with normal driving and normal acceleration upto 80km/hr in city
