Cost of engoine overhaul was aprrox Rs 25K in 2009.
murtaza did ur cars overhaul?.......so how is ur car so far?
Dear Test Driver:Yesterday I saw a Daewoo Racer which dashboard was changed with of Toyota Corolla. Have you any idea about that is it successful or not. More over is there any expert in dash board repairing in RWP/ISB? as my dashboard become noisy at the time of starting and releasing the clutch during move, rest OK.
dear its a good swap having a toyota 16 valve engine in daewoo racer as its body is very heavy and it fit complete on the bay one of my friend have a daewoo racer and he has this engine as the engine is to much power full and also the parts are easily available in the market in any city of the country.but if you want to keep this car then do all this stuff.i have already uploaded the snaps of the engine bay of the same car in which the 16 valve efi toyota engine is installed.
I am having a daewoo racer since last many years. I am not having any problem with it. But now the interior has become quite old, however the exterior is still fine. Can some one plz tell me any good mechanic / interior maker IN KARACHI NEAR GULSHAN IQBAL OR SADAR who can help me in fitting the daewoo ceiloo interior into my car. Moreover, can some one tell me about any good daewoo electrician near gulshan iqbal
Can some one tell me what all warning/indication lights are available in the daewoo racer dashboard meter.my break fluid container lights are hanging inside bonnet i.e not fitted any where. Where they will be fitted
0345-2285459 aslam mechanic.this guy is a good daewoo mechanic+electrician ,his shop is near Alladin park
THANX brother. Can this chap help in uplifting the interior. As I want to fit daewoo cielo interior into my car. What about the warning lights/indication which are available in the dashboard meter???????How many operational lights do you have in your dashboard meter????What about bear fluid container wires?????Can some one help me plz
daewoo cielo dashboard is bolt on job & no alteration is needed. call him for ur queries.and indication lights which r functional r=parking brake,door light,engine check light(orange in color)engine oil light,battery light.
whats the entire cost of fitting a ceilo interior in daewoo these days?
does any one knows any good electrician in lahore and also i wanted to share some thing regarding a.c. my cars ac fan is on direct meaning there is no relay installed...infact the mechanic removed it coz after repeated tries the relay would get short and the fan would turn on by it self..and would result in battery being dead so finally he removed the relay as a result the cooling is reduced. he said that the direct fan wil ve reduced speed rest cooling will be ok bt i noticed the cooling aint better now...what shall i do and plz do tell me if any one knows any good electirican in lahore or else i ve to visit isb as all the good workshops r in isb
please try Ramzan near Kainchee Pull.. his number is 03134667947..good luck
oh no not ramzan....he totally rips u off n ur car aswell.....i would never recomend anyone to go to him at all
@yousaf...where did u buy the mitsubishi lancer generator n for wat price?
our Racer had a accident with a pickup near Daewoo Express while our driver had taken it to Pickup a relative frm Daewoo Adda and the driver said that the car did a 180 spin when it was hit !! Alhamdulillah 2 people in the car were safe and the car was brought home safely... and the rear driver side door was pressed in and the bumper had fallen down so had to tie it frm one side... will start a thread when i take some snaps..
no activity for quite some time now......@shah ji i wanted to ask where do u buy petromin in lhr..i went to pico road but couldnt find any shop having it and is there any better oil? in the mkt? my car is currently on caltex havoline 20W50 and consuming a lot of oit...should i go for over haul or is it may b due to oil?.....kindly reply soon
iam daewoo lover an am facing break problm.is there any solution kindly contect,shan444@live.com
Too Bad....Thanks to Allah that passengers are safe!
If the engine is consuming "a lot of oil", take your car to mechanic for compression test before changing any oil!
