@testdriver:
Daewoo's genuine compressor is also reversible, means it produces hot air in winter.
what if sanden compressor is installed in the daewoo?
Normally in winter season, radiator fan is amde automatic, two specific water pypes are placed back and this mechanism helps to get the hot air. But actually this mechanism does not work on long routes because rapid inflow of cold air in the engine cabin does not allow the temprature to rise, hence hot air can't be produced.
is there any fault in the above mentioned mechanism. (i would have to check the thermostat valve whether or not its there in the engine)
is it possible to install some other heater componant in the car??
