@testdriver still helping others
@guybwp having same issue with one of my relatives cars we will diagnose it shortly as we both are busy, Issue is directly related to IAC valve but if issue still persists and this does not resolve issue then try to tighten the micro connectors of the sensor connectors. Also replace the VSS valve with an alternate(ok unit) and drive vehicle. Some elctronic faults arise due to change in capacitor value of the sensor circuit thus it is working but not providing 100% data
MOST IMPORTANT WHICH ENGINE ARE YOU USING STOCK TBI one, STOCK ENGINE WITH MULTIPOINT INJECTIONS SYSTEM OR DOHC one
@seismic check the connector rods of the gear box, slight force during installation can bend them and can cause hinderence in normal operation. Secondly there are small washels installed along joint of coonector rods, if they waer then play in gear shaft increases and there is hinderence to shifting of gears. Also check your clutch adjustment. If the problem after rectifying these issue is still present then problem is present inside the gear box (get it replaced)
FOR KABLI PARTS(Sultan Ka Kooh): Maqsood 03225820236 (you can give him my reference Doctor Shaan
and if want to strike a deal cant get hold of him contact me and i will resolve it for you at least he is honest)
FOR MECHANICAL/ELECTRICAL/PAINT: Khalid Friend Autos 03225111110
FOR PAINT(EXCELLENT QUALITY): Amjad 03009502868
@all been little busy usually was being mailed for resolution of issues. Met some PW and they recognized me and were stressing for me to give time to forum thus will try my best (Email me issue: mercs64@hotmail.com) and will get back to you on forum
THANKS FOR YOUR APPRECIATION AND SUPPORT
