@all
Daewoo plus behind fire brigade, Islamabad are good mechanics as it is run by Mr.Iqbal, old employee of Federal autos who opened this shop in 1998 after having issues with owner of federal autos,Mr.Bhatti(Late) at that time. His mechanics are good at work but they all including owner will try to rip you off and they handle the your vehicle not caring if it can be damaged or scratched via there ill manner treatment.
FEDERAL AUTOS I-10, islamabad has good/excellent mechanics but they will also rip you off if you are not on guard after there new incharge has taken over from past 4 years. Getting parts there has no issues as they have all parts including genuine/non-genuine available there. Wajid there is a good mechanic and very experienced but you should know how to tackle him. I am going to FEDERAL AUTOS since 1995 and i have no issue of satisfaction providing i supervise closely when repair/service is being carried out.
Most of the inquiries have been previously discussed in detail on the forum, new members kindly go thru the forum replies/discussion
@welcome786
Methods to verify clutch plate Problem : 1. Accelerate your vehicle suddenly and if you feel noise of engine higher i.e engine sound as if no gear has been engaged and acceleration very slow then this confirms issue. 2. while standing still partially release clutch while vehicle in first gear and note engine vibration during the release, if extensive then problem confirmed. 3. If vehicle is loaded with passengers and luggage and being accelerated. same problem as 1 occurs then problem confirmed.
Verifying engine Problem: Check if your engine drops oil level more than quarter of full mark in one week, engine issue confirmed 2. Blue/Blackish smoke in morning which reduces with engine warming(minor 1 cause will be accompanied by this issue) , engine issue confirmed.
Also check timing belt if properly tight. Check generator belts(use only corrugated one). Check A/C belt(use non corrugated one).
Get your vehicle checked by scanner for issues regarding sensor`s for pick/acceleration
Usually issue of acceleration if not related to engine/clutch/distributor then it is related to feul/CNG settings or wiring issues. If that is alright then get your Feul Pump checked or Map sensor checked
