@crystal5311 Thanks!!!
@fslrao as @testdriver correctly quoted. spray WD40 over the locks moving with key movement. Also spray some in side the key hole by slightly opening dust protector but do not stick any object inside the key hole. As for issue of fuel cap being getting stuck, every third or forth time you open your fuel cap for filling fuel get out of the car, spot the open oil for sale tray. There will be dipped/dropped oil in the storage rack. dip your finger in oil and rub it slightly over the black circular packing of the fuel cap which tightens with the fuel pipe. It should be mainly oily after application. This way you will have no issue fuel cap getting stuck. I learnt this method as my vehicle is used on petrol (no CNG) since 1995.
@guybwp I agree, if you are no expert, then there a lot of issues including price issues i.e. installation, selection of second hand parts. As I have a lot of knowledge in this field thus i have no issue. If there is any thing which i dont understand then i study the thing on net, read reviews of users on the website , discuss with mechanics and reach to conclusion and then practice the fact to practically test the theory and learn from the experience.
The bumpers are of Daewoo Racer GSI Fantasy 1993-1995. They are taken from used daewoo racer standing in scrap in korea due to tree fallen on the car destroying the cabin. They were imported via Karachi dealer thru Khalid & Amjad on my request after viewing it on net. Costed me 10000 extra. The engine block is same as of Daewoo Racer original. Changed the manifold and throttle system thus bought all supporting equipment including ECM as TBI engine has one injector and fuel is controlled by potentio setter whereas this throttle body has four injectors and fuel is controlled by N13 oxygen sensor or Lambda sensor. The cielo engine is same just upgraded throttle body for this displacement engine. Power window switch comes in the driver door of Cielo(original). The power steering of Daewoo racer and cielo are same. Only difference is adjustable steering column which comes in Cielo. The side switches p/W are of Toyota Corolla 1992.
You can get all these from Khalid Friend Autos I-9 islamabad 03225111110. You can give him my reference if you like
