Dear Sir, Eid Mubarak and hope you are good in health
well my daewoo got issue i recently fixed back daewoo's AC with gas charging e.t.c but now the issue is that the AC is behaving awkwardly that sometimes it switches on after i press ac button and start blower fan and sometimes it doesn't switches on even the button is pressed and the condenser fan is not working at all even when the ac is switched on (ac works like i have to pray for it) , i ve checked all the fuses and relays all are working fine, i ve checked the condenser fan its working fine and i ve spent few days in tracing wires of ac condenser fan and ac clutch all wires come to a relay then goes into ECU, relays are good ( ac clutch engages when i bypass that ac relay whose wire is going into ECU)
the car has been swaped with daewoo MPFI 1.5 engine with A/T with uncut wiring (so didn't had any issues with wiring at all from few years) what could be the issue
as when the ac stars to work then it does work untill i switch off the ac in the mean while as the car is idle the ac clutch engages and dis engages itself may be due to low power from engine)
if any brother have daewoo's wiring diagram of this MPFI engine it would be soo helpful.
