Currently my Daihatsu cuore fuel average is around 10 Kms per litre in city without Air condition model 2008, recently carborator is also serviced but not satisfied with fuel efficiency. Experts kindly suggest me the best way to tackle this problem.
What is this? There seems nothing in this pic. (at least to me).
Kindly edit your post, and / or re-upload the pic.
i have written my concern
Check ur brakes they might be dragging
if it is a local carb engine coure from indus you shall get the tappet adjustment ignition timing check replace spark plugs if required,. Distributor overhaul is highly recommended. Also check for hand brake adjustment. 12 year old car need through checkup for engine compression as well.
Yes its a carb engine from indus motors. Recently engine is completely overhaul so tappets are loose till 1000 kms running. I think brakes are also not working well and front wheels are getting heated so letsee after the service of brakes. Thankyou
Yes, letsee after the service of brakes thankyou
