I couldn't find this information anywhere for Daihatsu. Please clean your coolant temperature sensor with mild acid just to be safe.
The thermostats should be opening at 88.2 C. If your coolant reached 101 C, then something doesn't feel right.
Is your reservoir bottle filling up and emptying? Is the coolant being reduced?
In order to receive help, please explain the symptoms in detail.
