AOA..
I have just imported Mira ES its 7/2013 with just 11500km driven.
When I received the car and started for 1st time both ABS & Eco Idle lights were blinking. I was bit worried and started googling for the possible reasons. After reading many threads I found that there can be many reasons;
ABS Light. (ABS Fault triggered)
1- If 1 or more wheels move at different speed.
2- Different size of wheel or tyres installed on vehicle.
3- Car is driven with space saver wheel.
How to reset, remove + battery wire from terminal for 1 minute. After this drive the car around if all the 4 wheel & tyres are of same size the light will go off automatically. If this does not happen go to Toyota and get it scanned.
ECO IDLE.
Will not work in case of any fault like ABS & CVT.
When you start the car the light will be orange and blinking.
Start driving, with seat belt fastened the light should turn green after driving for few miles.
The max millage you should expect is between 16~18km/ltr.
If you want to turn off Eco Idle function permanently, select the ILL On from the right mode selector on the speedo meter, keep pressing it will change to ILL Off.
Happy driving.
One more thing; there is no second battery in Mira ES. There is only 1 battery in the engine compartment and same is used for all practical purposes.
I would also like to stress, that you should not chnage the tyres, type, size & width. The MIRA ES is equipped with low rolling resistant tyre "Yokohama Blue Earth; A34" changing these tyres will seriously effect the mileage.
