[quote="Newtechautos12, post:86, topic:226752, full:true"]
how the problem has resolved? because i am also facing the same problem, please help.
Can you specify in which form light is blinking? If it's in with orange light than usually it means that u r facing tuning issues and need to get it tuned up for EFI systems with support of professional tools and machines. If this is a cause we might help you in that tuning issue (if available in khi, you can visit us) . If eco idle light is blinking in green form than it need to be done with calibration. For all people I want to clarify that green light blinking ll not stable by negative terminal even if you ll remove it's ECU from car though. You must in need to calibrate it. In both blinking lights ( orange or green) eco idle and idle stop ll not work, not a single time untill unless you ll perform such required steps and procedure. If anyone having such issue in Karachi can visit us. Inshallah we ll resolve their issues.
Boss, Orange light is blinking... and it is not turning in to green, secondly the white light if battery charging is also not coming once this orange light started to blink, before two days everything was okay since last 5 months.. and this problem started on a running car.... i dont know what happen.
Dear Maddy,
Your car is for a time being in Alert Mode as your ECO IDLE changed into Orange light which means there is something electronically went wrong or you probably in need to get your EFI system tuned with computerized tuning. As for Battery alert, you need to check if you have reached to Maximum of your battery life or if you have wet cell battery than check if your liquid is up to mark and not dried already.
Rest you can visit us for thoroughly check up and solution for your car.
Regards,
Farrukh Farid.
Newtech Autos Karachi
[/quote]
ok thanks for the help.
do you check this problem? where you are located?
