anyways , yaar pata nahu kyun mujh ko aisa lag raha hai
the amount of SPL power is making on 126 db on CM-140
which may hit more DB at term lab ,
like what ever the pressure of bass ,(bahaut jaan lagani parh rahi hai system ko to make 126,127 db number ) its making hard to generate numbers of cm-140
where as on TL till 190dbs , it can make like 130+ SAME SPL of our cars
there is a Sensivity of MIC as well , the close it gets to its END limits , the hardest force is require to apply to hit the end number of your Limited of that DB UNIT spl meter
your max limit is 130db , i think lots of energy require to hit to 130db on CM SPl which may like 135+ on TL ,
when i told my friend , i hit 126db he was shocked he said 126 db cant flex out screen ,it cant to do nothing
ON YOUR CM-140 126~127 in between 40~50hz per hi demag kharab hogata ha with in 2,3min constant bass
HE HAVE HIS CAR AUDIO TEST ,have FI Q - 15" 800Wrms provided 143 on termlab a member from team BHP
(duty_riz you may know that group which i told you , remember???)
IF ITS TRULY 126 , sharam kay maray dobe marnay ka muqaam hai yaar
126db is nothing yaar in the world of EVEN SQL , even SQL hits louder
SPL to khair choro maza taab hai when a system starts with 140DB
