reading the plug off - requires a loupe - thats the easy bit - getting the heat range correct is the hard part.
e.g. classic Pakistani case.
Kawasaki KH1xx 100,110, 125 - it originally comes with B8ES - this plug is a regular tip cold plug, if the engine is tuned accordingly, it will never knock at high rpms and perform nicely and evenly on pulls.
Nearly all Pakistani mechanics use BP6ES - add too much fuel to compensate the supposedly lean condition. The engine usually knocks at high rpm and damages the piston/cylinder and conrod too.
If you put a BP6ES in a correctly tuned KH100 engine - it would show as super super lean. Install B8ES back, and it will show correct.
similarly, the daihatsu CB35 engine is a lean burn emmissions engine with higher CR than the CB23 (regular pakistan model charade engine)
It uses an NGK plug - with 7 heat range but extra projected twin electrodes to start the flame ball effectively because the charge is lean and messed with EGR. Using a BP6ES from the shop makes you think its perfectly tuned as it shows whitish electrodes - but infact the engine loses power as it knocks on high rpm and sometimes diesels while shutting down.
e.g. taking into consideration the mitsu galant 4G93 GDI engine, most high perf speed shops made a fortune from selling their owners platinum and iridium spark plugs again and again in the name of engine performance.
NOPES.
That engine is inherently prone to coking itself because of its very high CR - it produces carbon particulates like a diesel engine. When it cokes up it combustion chamber ball cavity in the piston - the plug cannot ignite the fuel mixture, as the compression ball is not centred as required. The original platinum plugs are good for 200,000 kms. but owners replaced them again and again. for the sake of speed shop placebo effect.
My remedy for the Galant GDI was replacement with a 6A12 or 6A13 from a similar Galant/Legnum - very simple engines, very smooth and very reliable - those engines are V6 - but use 3 platinum plugs for the rear bank and 3 copper ones for the front.. (which according to our PW members would be stupid)
