sir i didn't found anyone who does compression test for a diesel engine.
regarding radiator flush, how much citric acid to add in radiator ?
do i have to keep rpm continuously at 2000rpm or drive car for 15 mins or both ?
and then drain engine with hot water twice and i am done ?
1 bottle of pink toyota coolant is enough ? and distilled water is the one drained from ac or the one added in battery ??
CSD is working perfect, do i need to do something extra to clean it again or just citric acid flush because from last two months its working on tap water.
- hot starting issue is only when cranked without heater, valve clearances were check 2 months back and it was 0.28mm.
-for black smoke: i tried various fuel stations for diesel and best i found was Shell on nursery shahrah-e-faisal, car smokes regardless from where ever the diesel is filled and i will check and replace the fuel filter tomorrow.
after how many kms it is suggested to replace the fuel filter ?
