We have replaced the plunger assembly today and there is a significant difference in engine sound..lot less sound...it was producing a very loud n bad (forgive my total ignorance with engines) tick tick (somewhat like tappets in petrol) sound which is gone after CSD replacement and engine sounds seems somewhat normal now...vibration also has decreased a lot..but some of it is still there at idle which i doubt is because rpm meter is not working correctly and i ll have to get it fixed so we can fix the engine rpm where it should be....i doubt mechanic has checked nozzles or pump timings but judging by engine sound i think pump was timed before installing CSD...i ll double checked anyway...black smoke has also decreased but still there...
Also, @xulfiqar bhai, we filled 4.5 litre oil yesterday...in the morning when i checked oil level on dip stick it showed way above F...which worried me....but when i went to mechanic he showed me the dip stick was showing absolutely fine oil level i-e right at F level....what could be the possible reason for that..the ride btw,was standing on perfectly flat ground in both cases....
Sent from my SM-N900 using PW Forums mobile app
