AOA, @Xulfiqar.
-i am searching for a thermostat valve of corolla 2C engine from a long time but did not find any new or used, gone through plaza, mukka chowk, al asif diesel pathan mechanic market, etc and now i am loosing hope for it, kindly suggest any substitute for it.
-another problem with little background: i just returned from a trip of northern areas in my car, before leaving for the trip i changed all the glow plugs as two were taking more time else everything was perfect, valve clearances set, CSD working, pump timed with dial gauge and worked on by cummins, no issue of hot or cold start... now the problem starts when i was in bhurbhan (freezing temperature), i tried to start my car after giving 4,5 glow as it was very cold but it did not start, it was parked on down slope so i put the car in first gear, brakes off and it starts rolling, i left clutch n engine did started but shut off just as i left accelerator..... again did the same n this time pressed the accelerator for about 15,20 seconds on nearly 2K rpm so that engine does not shuts off n after 15,20 seconds i left accelerator and engine was idling but with severe knocking n missing n lots of white smoke on idling which vanished if accelerated upto 1800-2000rpm.. i let the engine idle n as it got some warmth it normalized and the missing n knocking vanished just after about 5mins of startup in that freezing temperature.
i drove it all the way from bhurban to lahore n then to sadiqabad and then to karachi and kept on facing the same issue on every cold start and still facing it.... before trip it used to start on single self on cold after single glow time but now it takes 7,8 selfs on every cold start with severe knocking n missing n white smoke which vanishes after 1km of drive in karachi, now i want to know whats wrong with the engine ? and what needs to be corrected ? it wasnt like this before facing the freezing temperature.
-here is the video link (i hope u can view it) of cold start just next day after returning from the trip and u can see in how many selfs it started,
https://www.facebook.com/video.php?v=10153200634349050&l=1152087975955488885
-on cold start rpm used to be on 1100 and decrease to 800rpm after coming to optimum temperature but now due to missing n knocking rpm on cold is 900-1000. consumption also seems to be increased after this issue which was 16-18 kmpl in city previously.
