A bit confused reading through the posts of respected members. From another diesel thread on pakwheels a while ago i switched to mobil-1 delvac for my 2.0d as at that moment caltax was exiting pakisran so delvac seemed like better chioice.
1 reading through the posts is mobil delvac a suitable good oil for a 2c . (Zero blow and no issues) or should delo gold be used instead.
2 might be a off topic thing but the crank seal on the 2c is leaking slightly and i have a set maintenance date for its replacement along with the belts and things. Should i get the oil-pump oring changed as well its not leaking at all but should preventative maintenance be done on it or should it be left alone.
Would appreciate of esteemed would share their thoughts
2006
2.0d
Nearly 180k on odo
