which website is it ?
Japan impex
which particular model
Looking into launch x431 pro 3 seems to be able to manage alot of things. As pretty sure x431 v+ wont be available locally @syncview
kindly tell me from where you purchase this tool ,,,,,,,,, i am also in search of this tool ,,,,,,,
Sir i ordered one from abroad
share the link ,,,,,,,,,,,,
Link sent
@effaf27please can you send me too?
@Xulfiqar Bhai !
For the temperature readings, does the ecu of 1hdfte relies on the same water temp sensor located near the oil filter or are there two different sensors for guage cluster and the ecu ?
And one more thing.
The timing and injected volume is controlled by the ecu on these (which is long way of saying EFI) so if a engine like this has been tuned by unichip or some other tuner, is it possible that the timing would have been messed up by him ? I know the AFR readings will be changed for sure but is it necessary to change the timing to gain more power ? Talking about the afr i guess 20:1 is the boundary line on a turbodiesel. Anything below this threshold would result in extremely high egts. Correct me if I'm wrong.
There are separate sensors.
what about this query?@Xulfiqar
There is no set afr on a diesel engine as its unthrottled. More accelerator means more rich.
We have to keep this in sensible range to prevent meltdown.
First step towards sensible range and correct timing is to make sure the injectors are perfectly adjusted on both stages, wrong break pressure causes timing havoc on the engine.
on a 1HDFTE one of them is located near the oil filter housing, can you please guide me where's the other one ?@Xulfiqar
@Xulfiqar PakWheels Forums 1KZ-TE Engine AoA Xulfiqar bhai. Although I am a long time pakwheels member, havent joined a discussion for some time. I request your valuable guidance regarding good mechanic in Karachi for overhauling/rebuilding my 1KZ-TE Prado engine. Location and contact information will be greatly appreciated. I know that you are the guru here. My engine is first time overhaul and therefore block in good condition. Should I go for .50 pistons or sleeves? I value your recommendation.Best RegardsDr. Akbar Khan
The single wire one is on other side of engine, that drives the temperature gauge. The ecu one is under intake manifold.
You can ask it in this thread too
