@Xulfiqar, sir today i have got the fans to auto, now fans are working in two speeds, when i switch on ac the fan is on low speed and when fan needs to cool down the engine at nearly 45% of heat gauge the speed is high. i think its normal as u discussed it in some other thread as well, will check this for a week and then pour coolant in the system.
now the problem is how do i ascertain that thermostat valve is fitted in my car or not ? when hot there is also pressure in the rubber pipes connecting engine and radiator (checked by pressing the pipes, it was hard to press).
glow plug indication/preheat indication timer is same when car is hot or cold even after fans being on auto, what to do ?
please suggest gear oil for my car - corolla 03, 2C.
power steering oil is little bit black and never changed (as far as i know at-least from last 7 yrs), going to change it tomorrow, shall i go for the normal/cheap power steering oil available or some other brand u'll suggest ?
