@ levin bhai,,,,,very difficult definition of horse power
i think u have copied it from a physics book,,,hehehehe
anyway for an ordinary man,,,,,,,,,watt is the unit for power
power= work done / time
another unit of power is horse power
relation btw them is 1 HP= 746 watts
atleast this is what i learnt in matric
now to calculate horse power:::::
If you want to know the horsepower of an engine, you connect the engine to a dynamometer. A dynamometer exrerts load on the engine and measures the amount of power that the engine can produce against that load.
cc on the other hand refers to the volume of the engine cylinders in which combustion of fuel takes place
the more is the fuel capacity of cylinders i-e the more is the combustion in cylinders which produces greater power and hence more horse power ,,,,,,,but there are other parameters to be kept into consideration,,,,,,,
this is why sometimes a car with higher cc can have a lower horse power,,,,,,,,,,,,,,,just as the case of civic exi and optra,,,,,,,,,,exi 1500cc ,,hp= 110,,,,,,,,,,,,,,,while optra 1600cc and hp=107
now can anybody tell me what is the work done in moving a bucket of water from one point in a circle back to the same point thus completing one cycle,,,????
the winner gets a Parwaz Fan
