In Pakistan, Mira ES comes mainly in two packages, one is the L package and the other one is the X package. Basically, the L is the basic package and the X package is the loaded one. The main difference between the two packages are as follows:
1. Simple Yellow color cluster meter in L package while the X package has a multi-colored cluster meter with two information displays.
2. L package doesn't have a keyless entry, while the X package has a keyless entry feature with an immobilizer.
3. L package has a simple plastic casing around the inside door handles and air vents and the gear lever, while the X package has a chrome casing and it looks more beautiful than a normal plastic casing.
4. Some X packages also come with Alloy rims, but some of them have normal steel rims with wheel caps.
I hope it helps.
By the way, if you're interested in buying Mira ES, I do have one Mira ES X package (Model: 2012/15) for sale.
For more details, please dm me.
Thank you.
