jab injen garam hota hai tu car long self kyun leti hai ya dosray self me start hoti hai
Check self and wiring , it’s common problem for bad self weak starts when hot . If your battery is old you have also consider to check battery
Indication of weak current which might be due to weak wiring, weak self, weak battery, weaker relays etc.
Or it may be heat sump problem....
check specific gravity of the battery electrolyte.starter motor need service, add extra 6mm copper ground from battery negative to engine block.
please define heat sump ?
It is a phenomena in which the resistance of wire is increased when heated and as the wire become old the heat increase the resistance that leads to weak crank...
Relays are often effected by this phenomena...
