Ok, on the back side of CNG conversion switching unit, there are RED, BLACK and WHITE color wire among other wires
RED wire is +12 V switched power, mean it powered on when, ignition key is ON position,
WHITE color wire is CNG presser signal wire that is coming from CNG sensor, installed on CNG kit,
BLACK color is chassis ground or -Ve battery power.
you want to make CNG meter that shows level on some digital display:), It would be easy if u have used some micro controller in ur projects. Cost should not more than 200 RS.
If u want to make, I can guide/help you step by step:)
