Well, In this case, put washer sensor on water out point bolt. Where place exactly u put the display?
Might be near the steering, below it or in the right most corner of the dashboard. I will however would like to add a feature in it that if the temp crosses a certain value, the instrument beeps.
Sent from my Nexus S using Tapatalk 2
oK , Well alaram/ beep funtion can be added easily in design. Let you start. I am here to help you. Think about how u make display box?Mostly time taking activity!This can be done with some plastic housing for this...
I have seen some digital temp sensor with LCDs on aliexpress.com, cost is about 500 PKR including shipping. They might not have the beep feature though
RS 500 including shipment! Then would be very cheap. But I think not the case. Either there are some min quantity order requirement or some hidden charges if u order single piece.As i know these kind of websites from china mostly do whole sale selling.They don't ship single piece or in other case price very high.You can try by giving order if it is really RS 500 including shipment charges.
free shipping LCD Digital Panel Thermometer Temperature Meter #9786http://www.aliexpress.com/item/free-shipping-LCD-Digital-Panel-Thermometer-Temperature-Meter-9786/286561867.html(from AliExpress Android)
Here is the link. But i noticed that the temp range is low...just upto 70 oC, T-stat valve opens at 82oC
This one is about double the price but temp range is upto 125oC
There also shows shipping Cost:US $30.79 to Pakistan Via EMS <dl><dd> </dd></dl>
Its free through China Post
Hello, i also designed digital CNG switch.... prototype and its coming soon for commercial use... same functionality with cng low alert via buzzer. . One button Programmable auto cng to petrol switch when cng low... i'll be adding more feature in this small PIC with GLCD.. if you have any other ideas to be added in it plz comment. and yes PIC is great :)
Good work, keep it up
can you make your multimeter two piece, like i can install the chip somewhere else and connect it to the screen with a wire
Hey Bro: Nice work. I also am EL. engineer from NED :). Would you mind share more technical details like interfacing the CNG sensor and other sensors and all. Thanks
Ok, let me know your requirements for this .
I will let you know when I want it, abhi budget urr gya hai, I plan to have engine temp, rpm , and batt voltage, there is a compartment in my car that has its door broken, I want to fit the screen there and hide the circuitry elsewhere
Thanks... any more ideas you would like see in this little circuit ?... i want to make this very useful for others.... so if you or someone who is reading this have any ideas which you think need to be added will be great..
Thank You
