ok! this seems to be more practical...
but after my long research i found this! in this pic you can see that resistor is connected to negative side of led and negative wire from source?????
but after my long research i found this! in this pic you can see that resistor is connected to negative side of led and negative wire from source????? @umair911
Try karlo both ways, bohat bhe hua it will only burn 3leds, but atleast u wud learn something for sure!
yar ap ik bt btao apki leds work kar rahi hn q k mujhe kisi ne kaha k zayada accelerate karne par led phat na jae... mjhe thori hasi aii magar phr me thori cnfusion me agaya??
Haahahaha....u made my day man! Nae phatain ge LEDs!
after listening to the guy . I was like"bhhai apne electronic engineering kaha se parhi he?"
Your power source is battery so acceleration wont effect current to LEDs, if u had connected LEDs with ignition coil (which u wont b doing) then this glow based on speed/acceleration qould have been the case!
final result(brakes applied)
brakes applied
parking light
@umair911 and @rozzzzz bhai howz that?
@sohaib.usmani1 @cool_shahraizKindly share steps of construction & associated cost
Bought new brake light covers as mine were almost done. Material was just LED lights available in different colors I bought red as for the brakes and sticked the LED lights with hot glue gun to the back of the brake light cover. I only gave them the parking lights connection so they are turned on when the parking lights are on only giving them longer life because when you put them on brakes they will light up Everytime and reduce led light life.
Replied
