2. Throttle Body Service
First, disconnect all attached sensors by unplugging their harnesses.. These will include the MAF sensor (placed on the air intake pipe), the MAP sensor (placed on top of the throttle body - also in this image), TPS or throttle position sensor (placed behind the throttle body) and the IACV sensor (this is placed underneath the throttle body in A/T version of this civic)
Then you take out the intake pipe.. disconnect it from the one end connected to the throttle body and the other one to the air cleaner housing
Here is a view with the intake pipe disconnected
Now a challenge in removing the throttle body was to remove these two cables that are attached to the fly on the throttle body
Here you see the first one is detached
The CNG venturi removed.. to detach this, I had to unscrew two screws which fastened it to the throttle body..
This is the second cable, removing it was a bit of a challenge, I had to unscrew the metal plate which was attached to the throttle body as well.. it came out after I did that..
Both cables are now disconnected
A shot of the dirty and gunky throttle body.. if you notice the top two corners are unscrewed, there was a bolt on one and a nut on the other.. I then went on to unscrew the two at the bottom..
and here you can see the throttle body disconnected from the intake manifold.. However there are still two water pipes connected at the bottom of the throttle body, had to disconnect those before I could take it out..
These are the pipes below that had to be disconnected.. and water poured out when i did that..
At LAST! Success! The bad boy is out.. and ready for its cleanup..
Very dirty..
This is the bottom of the throttle body, this solenoid you can see attached with a lot of screws is where the IACV is and that plastic thing sticking out is the IACV sensor..
I stuffed the inlet manifold, just in case. To avoid anything from going inside while the throttle body was removed overnight.
Here's the advantage of working with a pair of gloves, automotive dirt is so greasy, its a hassle to get off - and for safety too, i recommend using gloves.
Getting all the things ready to clean up the throttle - a tub, all my tools, petrol, WD40 and a tooth brush is what will be used
The next three pictures are for before-after purposes..
AFTER removing all the sensors attached to it (these were the MAP, TPS and IACV sensors) start to clean up..
Wash it generously with petrol..
Use a toothbrush to clean in the groves also and clean the throttle body inside out a couple of times..
And you will see a lot of unwanted matter left behind.. and cleaned off of your machine..
I tried to open up the IACV but the screws on it were so tight and they are so old that trying to open them were just effing the heads up..
So I just poured in petrol and WD40 from the inside of the throttle body into the IACV and cleaned it up that way..
After the cleanup.. the screws and nuts getting some WD40 on them..
Installed all the sensors back on to the throttle..
And here is a serviced, clean throttle body..
THE TROPHY
