the tools. most important is having the right tools otherwise simple tasks turn into misery
getting the belt on pullies
putting tension by moving alternator on its slider bolt,, note the idle set controller comes right on the same path where alternator is,, special care is needed when adjusting the alternator with metal rod, one slip and it will hit the black plastic controller breaking that to pieces, as yr trying with force to tension the alternator belt
making sure the pullies all in the belt..
